helt ny dartmoor singelspeed ramme selges pga feilkjøp.
ramma er ny i esken med nytt styrelager.
Specs:
ny dartmoor shine 2011 frame, size: 11,2 + X-Fusion O2 RCX Air + Headset
Main changes comparing to 2010 frame:
Tapered HT
ISCG-05 mount
Custom designed, shorter dropout
New profiles of CS and SS tubes
Shorter chainstay
Specification:
Butted and heat treated 7005 aluminium tubes
Frame travel: 100mm
Shock: 190x50mm
Suspension ratio: 1:2
Rear triangle: 403mm
Top tube: 554mm
BB: Euro 73mm
Seat post diam.: 27.2mm
Dropouts: 135x10mm
Weight: 2,85 kg
selges for kostpris på 8500kr. ta kontakt , fetere ramme skal du lete lenge etter!
93457150 hele døgnet;)
email: cepetis7@gmail.com
