SELGER Stumpjumper FSR Expert EVO 2011 mod
SELGER Stumpjumper FSR Expert EVO 2011 mod #1164894 04/05/2011 21:16
Registrert: Jan 2009
Benny Banditt Offline OP
Selger Stumpjumper FSR Expert EVO 2011 mod
Sykkelen er brukt 1 gang.
selges pga den er for liten
Selges for den nette sum av 25.500,-
Fargen er sort.
Størrelse midium
TLF 48168165
http://www.sykkelbutikken.no/sykkel/terreng/specialized-stumpjumper-fsr-expert-evo-011//
RammeM5 manipulated alloy w/ ORE TT/DT, EVO geometry
BakdemperFox RP23-S with Boost Valve, reb and separate climbing setting and custom 3-position low-speed comp adj
GaffelFox F150 RL, 15mmQR, tapered HT
Styrelager1-1/8 and 1.5" Threadless, Campy style upper with 1.5" lower
StyrestemSpecialized XC, 3D forged alloy
StyreSpecialized Enduro low-rise bar, 7050 alloy, 720mm wide
HolkerSpecialized lock-on
BremserCustom Avid Elixir CR SL
KrankgirSram X7, 10d, bottom pull
BakgirSram X0, 10-delt, medium cage
GirskiftereSram X9, 10-delt
KassettShimano HG81, 10-delt, 11-36T
KjedeKMC X10, 10-speed
KranksettCustom SRAM Carbon S-2200, 10-speed AM double
Kjederinger36A x 24A, 4-bolt, 104/64mm
KranklagerSram PF-30, Press-in bearing
HjulsettRoval Traverse AL, alloy disc, 26mm, 27/32h
Dekk foranS-Works Purgatory, 26x2,2"
Dekk bakPurgatory Control, 26x2.0"
SeteSpecialized BG Henge Comp
SetepinneSpecialized Command Post, 3 position, 125mm adjustable height w/air spring, remote operated
Re: SELGER Stumpjumper FSR Expert EVO 2011 mod [Re: Benny Banditt] #1164897 04/05/2011 21:17
JonahHex Offline
Leppedefekt kåbbåj
Leppedefekt kåbbåj
...har du to stykker??
Re: SELGER Stumpjumper FSR Expert EVO 2011 mod [Re: JonahHex] #1164904 04/05/2011 21:24
Nei surra det til når jeg la den ut.
Hvordan fjerner jeg den ene av de to anonsene?
Re: SELGER Stumpjumper FSR Expert EVO 2011 mod [Re: Benny Banditt] #1166133 06/05/2011 14:02
Miniman Offline
Hei. Sendt deg en mld men ingen svar. Fremdeles tilsalgs? Ta kontakt på 93217244
Mvh Morten
Re: SELGER Stumpjumper FSR Expert EVO 2011 mod [Re: Miniman] #1167413 08/05/2011 17:14
Solgt
