SELGER Stumpjumper FSR Expert EVO 2011 mod
SELGER Stumpjumper FSR Expert EVO 2011 mod #1164850 04/05/2011 20:46
Registrert: Jan 2009
Benny Banditt Offline OP
SELGER Stumpjumper FSR Expert EVO [b]2011 mod[/b]
Dette er sykt digg sykkel som skal selges for den nette sum 25.500-
Sykkelen er brukt 1 gang og er i fargen sort størelse midium
Selges pga. trenger større sykkel.
TLF 48168165
Sjekk ut nettsiden: http://www.sykkelbutikken.no/sykkel/terreng/specialized-stumpjumper-fsr-expert-evo-011//
RammeM5 manipulated alloy w/ ORE TT/DT, EVO geometry
BakdemperFox RP23-S with Boost Valve, reb and separate climbing setting and custom 3-position low-speed comp adj
GaffelFox F150 RL, 15mmQR, tapered HT
Styrelager1-1/8 and 1.5" Threadless, Campy style upper with 1.5" lower
StyrestemSpecialized XC, 3D forged alloy
StyreSpecialized Enduro low-rise bar, 7050 alloy, 720mm wide
HolkerSpecialized lock-on
BremserCustom Avid Elixir CR SL
KrankgirSram X7, 10d, bottom pull
BakgirSram X0, 10-delt, medium cage
GirskiftereSram X9, 10-delt
KassettShimano HG81, 10-delt, 11-36T
KjedeKMC X10, 10-speed
KranksettCustom SRAM Carbon S-2200, 10-speed AM double
Kjederinger36A x 24A, 4-bolt, 104/64mm
KranklagerSram PF-30, Press-in bearing
HjulsettRoval Traverse AL, alloy disc, 26mm, 27/32h
Dekk foranS-Works Purgatory, 26x2,2"
Dekk bakPurgatory Control, 26x2.0"
SeteSpecialized BG Henge Comp
SetepinneSpecialized Command Post, 3 position, 125mm adjustable height w/air spring, remote operated
Re: SELGER Stumpjumper FSR Expert EVO 2011 mod [Re: Benny Banditt] #1167414 08/05/2011 17:15
solgt
