Må nok kvitte meg med landeveis sykkelen min. Noen som har lyst på?
Størrelsen er 58 og utstyret er Centaur. Årgang er 09. Nypris på nesten 30. Gått ca 200
Frame:
928 Carbon M - C2C with Kevlar insert ST
Fork:
FF9 K-VID Full Carbon with Kevlar insert 1 1/8 inch, Bianchi, L300 -
Front Derailleur:
Campagnolo Veloce 10s clip-on front derailleur
Rear Derailleur:
Campagnolo Centaur 10 speed rear derailleur, Short cage
Shifters:
Campagnolo Centaur Ultra Shift Carbon 10 speed Ergopower
Chainset:
Campagnolo Centaur Ultra Torque CT 10 speed crankset 170-172-175 mm
Chainrings:
34/50 tooth chainrings
Bottom Bracket:
Included in the crankset
Cassette:
Campagnolo Veloce UD 10 speed sprockets 12-25 tooth range
Chain:
KMC DX10SC 10 speed
Front Brake:
Campagnolo Veloce D Skeleton brakes
Rear Brake:
Brake Levers:
Integrated
Handlebars:
K-Wing Carbon Aero/Anatomical, Color Graphics grey/white ; HB-RK235;40-42-44cm Width x 31.8mm Clamp Dia x 14.5cm Drop x 9cm Reach
Stem:
Fsa OS-190LX 3D forged AL6061, Alloy Cap forged 4-bolt, bolt Chromoly Hardware, Angle +/-6 degrees x 100-110mm x 28.6mm Steerer x 31.8mm Bar Clamp, 90-100-110-120-130mm, Shiny Black finish
Headset:
Fsa Orbit CE Plus
Grips:
Ribbon cork
Rims:
Campagnolo Scirocco black
Front Hub:
Rear Hub:
Spokes:
Campagnolo SCIROCCO black
Front Tyre:
Vittoria Rubino Slick 700x23 60TPI folding bead, Kevlar Endura 3D Compound, Twin tread tecnology, PRB protection, Black colour
Rear Tyre:
Tubes:
19/23-622 Valvola alta 42mm
Saddle:
Fi'Zi:k Aliante Delta
Seatpost:
Fsa SLK - Carbon SP-RK-260 ,SL-K SB25, 2-piece 1 Bolt adjustment / Data Head 350mm Length x 31.6mm Diameter x 25mm Setback
Seat Binder:
Fac Michelin "X Carbon System" 36 mm, Black with Bianchi logo
Accessories:
Bianchi Hydra waterbottle
