Nytt fra Ibis: Mojo SL-R er lansert
Nytt fra Ibis: Mojo SL-R er lansert #1151395 14/04/2011 16:24
jeth Offline OP
Camoboy
Camoboy
Etter mye spekulasjon er den Mojo SL-R lansert og den ser helt fantastisk bra ut ICON_SMILE En evolusjon mer enn noe helt nytt, men tror de har tenkt riktig fra A-Å.
Fra mtbr.com:
"Very Stiff - This frame incorporates all that was learned with the Mojo HD frame. It shares the downtube of the HD and is overall 80-90% as stiff as the HD.
Real Light - Large frames are coming out at 4.95 lbs. New molding techniques are being used as Ibis has gone to a better manufacturer. The famous Ibis ‘cross-brace’ in the frame used to leave foam material in the production process. It is now completely hollow.
Tapered Steer Tube - This simply is one of the greatest advancements in frames today as it adds noticeable front end stiffness while adding very little weight
Bb92 Bottom Bracket – great for molding, really light and stiff translating to better acceleration.
Direct mount front der – simpler, cleaner and is ideal for 2×10 or 3×10 setups.
142 mm maxle - HD is 135mm right now so this leapfrogs it and jumps to a new level of rear end stiffness.
HD cable routing – This is the cleanest version of Mojo cable routing.
Bigger chain stay plate – A little more chainsuck protection is one of the things learned from all the real-world experience out there.
Integrated carbon brake post mounts – save weight with a cleaner design.
69 degree head angle with 140mm fork - This is a bit controversial as this head angle is unchanged from the Mojo SL. It seems they did not want to creep into HD territory. A frame this stiff and burly though seems to warrant a slightly slacker head angle. The good news is there’s the new Cane Creek Angleset headset and the head angle can be adjusted all the way to 67.5 degrees.
Colors - 4 will be available with the cool new graphic treatment. White, Orange, Silver, Black"
Awesome, Ibis ICON_SMILE
Redigert av jeth; 14/04/2011 16:25.
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1151398 14/04/2011 16:29
Jonas88 Offline
Å Herregud, den fikk jeg lyst på!
Hva blir pris i Norge tro...
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Jonas88] #1151401 14/04/2011 16:34
Becker'n Offline
Fin men dyr. 100$ mer en HD http://www.ibiscycles.com/bikes/mojo_sl-r/
Espen
Redigert av Becker'n; 14/04/2011 16:38.
Ibis Mojo SL
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Becker'n] #1151413 14/04/2011 16:58
Registrert: Jan 2007
gladegp Offline
Men 69 grader er litt 2008...
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: gladegp] #1151414 14/04/2011 17:00
Registrert: Aug 2003
nicolai Offline
Fordi..?
/Are Nicolai
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: gladegp] #1151418 14/04/2011 17:07
Loki Offline
Sitat: gladegp
Mens 2011 er ...?
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: gladegp] #1151421 14/04/2011 17:09
Becker'n Offline
Sitat: gladegp
Cane Creek AngleSet compatible, so the head angle can go down to 67.5º
Espen
Ibis Mojo SL
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Becker'n] #1151427 14/04/2011 17:22
Registrert: Oct 2001
Trond Vidar Offline
I want to ride my bicycle
Lekker!
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Trond Vidar] #1151437 14/04/2011 17:32
Statham Offline
nei å nei, jeg som er så svak for blått... daamm den var lekker...
Scott Scale SL 29
Scott Foil Premium
Ibis Mojo HD C
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Trond Vidar] #1151438 14/04/2011 17:37
jsdk Offline
Så helt klart lekker ut! Likte Tron-looken på første bildet her..
Men, for oss som ikke kjenner så mye til Ibis' lineup og som må ha allt inn i kategorier og bokser med maskinskrivne etiketter; er dette en mer trailorientert ramme enn Lopes-i-Whistler HD-en? Eller kanskje mer en videreutvikling av SL, som navnet tilsier?
..Eller kanskje bare rett og slett en flott ramme, som river sti ICON_SMILE
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: nicolai] #1151445 14/04/2011 17:43
jens fredrik Offline
Sitat: nicolai
Fordi..?
... de fleste nylanserte stisykler med samme mengde vandring har mye slakkere vinkler i 2011. Det er ikke nødvendigvis alles smak eller det eneste rette, men jeg er tilbøyelig til å være enig i at det er en smule gammeldags.
Siden man kan klaske på et styrelager som endrer vinkelen er ikke dette nødvendigvis så problematisk, men nettopp derfor burde de plassert seg i midten av hva kundene kan tenke seg. Jeg har store problemer med å tro at noen kan tenke seg brattere enn 69, men det finnes nok folk som vil ha slakkere enn 67,5. Hadde den vært 68 grader stock kunne man lett oppnådd både 69 og 66,5 og alle ville vært lykkelige.
Når det er sagt er ikke dette noen overraskelse. Lopes måtte overtale Ibisfolka til å sette opp HD'en med 67 grader styrevinkel, som i seg selv ikke er særlig revolusjonerende og slakt.
Jeg må si at det er mye jeg liker med sykkelen, særlig at de har fått til et ganske lavt krankhus, men 69 grader styrevinkel. Sorry ass, det er faktisk litt 2008 på en stisykkel med 140mm vandring.
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jens fredrik] #1151456 14/04/2011 17:57
nicolai Offline
Jeg tror at som en lett, rask stisykkel bygget med solide, gode deler vil styrevinkelen fungere fint. Ibis lager jo mer XC-orienterte sykler enn en del andre, så det blir jo en del av pakka, liksom.
Men jeg er enig i at de sikkert kunne gått mot slakkere, og jeg er enig i at jeg tror de færreste ønsker brattere enn 69.
Jeg vet bare at det er så utrolig mye mer som virker inn på hvordan en sykkel oppleves, så jeg ville ikke overfokusert på det heller, all den tid jeg tror det er helt innenfor slik det er nå også..
/Are Nicolai
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jsdk] #1151482 14/04/2011 18:40
heinrich Offline
hm, nais, men jeg må innrømme at det ikke får meg til å hive meg på telefonen og kjøpe en, langt der i fra egentlig. Heldigvis kanskje ICON_WINK HD'en frister mer.
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: heinrich] #1151519 14/04/2011 19:25
jeth Offline OP
Camoboy
Camoboy
Grunnen til at de er gått for 69 grader er nok rett og slett at de må ha _noe_ som differensierer den fra HD 140.
Jeg vil vel nesten si det såpass sterkt at de med denne i praksis mer eller mindre vil drepe etterspørselen etter både SL og HD 140, men jeg mener denne uansett virker så gjennomtenkt og ser så bra ut at total salget muligens (forhåpentligvis) vil øke.
Redigert av jeth; 14/04/2011 19:27.
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Becker'n] #1151522 14/04/2011 19:30
jeth Offline OP
Camoboy
Camoboy
Sitat: Becker'n
Sitat: gladegp
Ja det blir vel helt ned til 67º hvis du regner utifra en 150 mm gaffel som den er "godkjent" for.
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1151549 14/04/2011 20:01
polkaDOT Offline
Men hva er helt meningen med denne rammen?
Rammen er noe av det fineste jeg har sett, men meningen å erstatte Mojo SL, eller meningen å ha en litt mer rittvennlig 140?
På bilde ser det ut som det er litt mer ala Liteville 100 -140 mm enn ren 140 sykkel. Eller jeg er helt ute og kjører?
Litt skuffet, tenkte de enten skulle lansere noe 29" eller rittmaskin...
Ride your bike, and be happy!
Team Ibis / Probike
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: polkaDOT] #1151575 14/04/2011 20:28
runermm Offline
Tror hensikten rett og slett er å lage en helvetes stimaskin, noe de sannsynligvis har lykkes med. Mojo SL går nok ut av sortimentet når lageret er tomt.
Å oppgradere fra den første Mojoen til SL så jeg ikke noen stor grunn til, men å hoppe på en SL-R virker farlig forlokkende. Det eneste er at Mojo 29 lanseres på Eurobike etter sommeren...
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: polkaDOT] #1151642 14/04/2011 21:55
jeth Offline OP
Camoboy
Camoboy
Sitat: polkaDOT
Da ryktene om denne begynte å sirkulere for noen dager siden var jeg og litt skuffet, og trodde ikke helt at dette skulle være "det hele". Men etter å ha studert detaljer, bilder og intensjoner så er skuffelsen gått over. Jeg er tvert imot veldig imponert over hva denne tegner til å bli, og siden jeg tross alt er blitt en Ibis fanboy er jeg ganske sikker på at dette blir den nye benchmarken i kategorien.
29" kommer senere i år, der har de sagt at prototype skal vises på Eurobike, og en lettere rittvennlig sykkel føler jeg meg rimelig sikker på kommer om ikke alt for lenge. Jeg tror fremdeles den svarte split-pivoten vi snakket om i en annen tråd er en Ibis, for å si det sånn... ICON_WINK
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1151646 14/04/2011 22:10
polkaDOT Offline
Uansett kommer jeg ikke til å kjøpe meg en Ibis.
Har bestemt meg for en ny Liteville med 160 og ny farge. Svart blir for svart. Kommer sikkert til å stå på den ideen inntil jeg personlig tester en Ibis Mojo HD ICON_WINK
Team Ibis / Probike
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: polkaDOT] #1151654 14/04/2011 22:27
jeth Offline OP
Camoboy
Camoboy
Du får bare sende meg en melding hvis du er hypp på å teste min.
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1151716 15/04/2011 06:49
Registrert: Dec 2003
Arne_And Offline
Sitat: jeth
Sitat: Becker'n
Sitat: gladegp
Og det er kanskje en bedre match, så ikke kranken blir for lav (selvsagt avhengig av hvor man vil sykle).
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1151726 15/04/2011 06:56
Trond Vidar Offline
Sitat: jeth
Sitat: polkaDOT
Jeg er fan av evolusjon når produktet er så sterkt. Ibis har fulgt dette prinsippet en stund nå. En fantastisk sykkel som utbedres med erfaring er ingen dum strategi. Regner med at SL-R kommer til å få meget gode attester.
Redigert av Trond Vidar; 15/04/2011 06:57.
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Trond Vidar] #1151822 15/04/2011 08:41
polkaDOT Offline
Noen som vet hvilken sang blir spilt i bakgrunnen på klippet?
Team Ibis / Probike
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: polkaDOT] #1151830 15/04/2011 08:51
Registrert: Mar 2011
nitro2000 Offline
eric clapton - little wing
jimi henrix, egentlig
Redigert av nitro2000; 15/04/2011 09:01. Rediger grunn: jimi henrix
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: Trond Vidar] #1151861 15/04/2011 09:59
Nå fikk jeg lyst på ny sykkel igjen. Hadde en liten drøm om en 140 HD, men når SL-R er der, passer jo den min filosofi godt ICON_WINK
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: baronKanon] #1151915 15/04/2011 11:16
simenf Offline
Jeg tror at 29ern som kommer vil bli veldig lik SL-R.
Det er en grunn til at de måtte bli ferdig med denne før de kunne ferdigstille 29ern. Jeg tror på 120-130mm bak og tilsvarende foran og trolig litt justerte vinkler.
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: simenf] #1152673 16/04/2011 15:02
jeth Offline OP
Camoboy
Camoboy
Og på den andre side kan det tenkes 29eren er ulikt alt annet du har sett før og at det er grunnen til at de ikke lover "mer" enn at de skal vise frem en prototype på Eurobike. ICON_WINK
Jens
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: jeth] #1152715 16/04/2011 16:22
polkaDOT Offline
Hva er dette? Ny hardtail på Sea Otter?
Team Ibis / Probike
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: polkaDOT] #1152721 16/04/2011 16:33
runermm Offline
Den heter Silk SL, så det er nok en lettvektsversjon av Ibis sin landeveiskriger. Fikk plutselig lyst til å sluke asfaltmil!
Re: Nytt fra Ibis: Mojo SL-R er lansert [Re: runermm] #1152752 16/04/2011 17:32
polkaDOT Offline
Jammen fin landeveissykkel. Litt klassiske rør, med moderne utseende.
Team Ibis / Probike
