Specialized Stumpjumper Comp FSR Large Stisykkel
Specialized Stumpjumper Comp FSR Large Stisykkel #1146441 07/04/2011 17:08
9
92er Offline OP
Specialized Stumpjumper Comp FSR Large 2009
Sportslig, fulldempet stisykkel selges. Sykkelen har nok vandring til teknisk stisykling, men kjennes også kjapp på grus. Mulighet for å låse både for- og bakdemper (uten at det er så ofte brukt). Large-modellen har ekstra store bremseskiver. Kjøpt ny på Torshov Sykkel høsten 2009, kvittering medfølger. Brukt 2010 sesongen. I god stand, har vanlige bruksmerker etter stisykling. Framdekk Maxxis Advantage 2.4, bakdekk Specialized Eskar 2.3, ellers orginalt utstyr.
Ramme: Stumpjumper FSR M5 manipulated alloy frame w/ ORE TT/DT, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
Gaffel: Fox Float 120 RL, 120mm travel, compression and rebound adj. w/ LO, alloy steerer
Bakdemper: Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 7.25x1.75
Bremser: Custom Avid Elixir R SL, alloy backed organic pads, S/M: 185mm, L/XL: 203mm rotor
Girskifter: SRAM X-7, aluminum trigger, 9-speed
Krankgir: Shimano M660 SLX, DMD, top swing, dual pull
Krank: Custom Shimano FC-M542, S: 170mm, others: 175mm
Nav: Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
Felger: Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
Kjede: SRAM PC-971, 9-speed w/Power Link
Kassett: Shimano HG61, 9-speed, 11-34t
Styre: Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
Stem: Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
Sadelpinne: 2014 butted alloy, single bolt setback, 30.9x350/400mm
Sadel: Specialized Format, hollow Cr-Mo rails, SL foam, S/M: 130mm L/XL:143mm
Pedal: Shimano M520, clipless
Veiledende pris: 25 999,-
Specialized Høyde : L 175-185 cm. Til stisykling passer nok sykkelen også for dem som er litt høyere enn 185.
Prisantydning kr 12 000/bud.
Redigert av 92er; 07/04/2011 17:16.
Re: Specialized Stumpjumper Comp FSR Large Stisykkel [Re: 92er] #1146476 07/04/2011 17:54
joachia Offline
Hei,
Jeg er interessert i sykkelen! Ring meg på 48093395.
Joachim
Re: Specialized Stumpjumper Comp FSR Large Stisykkel [Re: 92er] #1151441 14/04/2011 17:38
9
92er Offline OP
Bud mottatt på kr 11 250
Re: Specialized Stumpjumper Comp FSR Large Stisykkel [Re: 92er] #1151532 14/04/2011 19:38
flyracing Offline
kor sykkeln står ???
Intresser :
Sykkling (e ute ette en sti/downhill sykkel )
Motorcross (trail)
Biljard
Foto
Re: Specialized Stumpjumper Comp FSR Large Stisykkel [Re: flyracing] #1155393 21/04/2011 10:23
9
92er Offline OP
Solgt!
