FELT B2 Pro temposykkel str 54 kr 20 000,-
FELT B2 Pro temposykkel str 54 kr 20 000,- #1145567 06/04/2011 15:50
Oyvind HD LCK Offline OP
Selger min nesten helt ubrukte Felt B2 Pro temposykkel grunnet avtale med et annet sykkelmerke. Den var ny i fjor og har kun blitt benyttet på et par treninger og kjørt med på noen ritt. Det følger med Swiss Stopp bremseklosser som er brukt kun 2 ganger.
Selges for 20 000,- kroner.
Ramme: Felt Tri Specific HM High Modulus Modular Carbon Fiber Frame. Full Aero Tubeset with front and rear wheel recesses, internal cable routing, forged horizontal dropouts
Gaffel: Felt Bayonet SL UHM Ultra-high Modulus Modular Carbon Fiber Carbon Monoquce Design with 3KP Finish, Carbon Blades, Dropouts, Crown & External Steerer with Felt 1 inch Bearing Compression Device
Front Derailleur: Shimano Dura-Ace 7900 braze-on, double
Rear Derailleur: Shimano Dura-Ace 7900 SS Short Cage
Shifters: Shimano Dura-Ace SL-BS79 bar end, 20 speed
Chainset: Shimano Dura-Ace (Helt nytt)
Chainrings: 53/39 Tooth chainrings
Bottom Bracket: Shimano Dura-Ace Hollowtech-II
Cassette: Shimano Ultegra
Chain: Shimano Ultegra 10-Speed
Front Brake: Shimano Dura-Ace 7800 Super SLR Dual Pivot with Cartridge Brake Shoes
Rear Brake: Shimano Dura-Ace 7800 Super SLR Dual Pivot with Cartridge Brake Shoes
Brake Levers: TRP Aero Carbon
Handlebars: Felt Bayonet 6061 T6 Base Bar with Integrated Adjustable Length 7075 Aluminum Bend extensions and Alloy arm rests with High Density Foam Pads
Stem: Felt Bayonet SL Integrated 6061 3D forged Aluminum, Rise: -17 degree thru +43 degree range of adjustability, 95, 110, 125mm
Styrelager: Felt Bayonet 1 inch Integrated
Grips: Devox Tri-tip Ergonomic Base Bar grip with Felt Gel Ribbon Cork Tape Black with Felt 3D Logo wrapped extensions
Hjulsett: Shimano Ultegra 6700 dekk_og_slange
Dekk: Continental Grand Prix 4000 S
Sete: Felt 3.1 Tri/TT Saddle with Carbon Injected base, Gel Nose, Custom Waterproof Cover with Carbon Fiber Inserts and Extended Length CRN/TI rails
Seatpost: Felt 3.1 Carbon Fiber Bladed Monocoque Design x 310mm
Seat Binder: Integrated Two Bolt Replaceable Clamp
Vekt: ca 8 kg
Vedlegg Felt B2 Pro 008.jpgFelt B2 Pro 003.jpgFelt B2 Pro 004.jpgFelt B2 Pro 007.jpg
"Euro. It's not an origin or place of manufacturing. It's a style or an essence."
www.lillehammerck.no
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1146054 07/04/2011 09:18
bump
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1147674 09/04/2011 13:51
bump
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1147747 09/04/2011 17:04
Registrert: Dec 2009
faandrem Offline
fin sykkel Øyvind
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: faandrem] #1149603 12/04/2011 09:36
19 000,- kr
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1153665 18/04/2011 09:14
bump
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1155550 21/04/2011 17:44
bump
Re: FELT B2 Pro temposykkel str 54 kr 20 000,- [Re: Oyvind HD LCK] #1156340 23/04/2011 13:38
bump
