Selger min nesten helt ubrukte Felt B2 Pro temposykkel grunnet avtale med et annet sykkelmerke. Den var ny i fjor og har kun blitt benyttet på et par treninger og kjørt med på noen ritt. Det følger med Carbon bremseklosser som er brukt kun 2 ganger. NB: Det følger ikke med Zipp hjulsett, men Ultegera 6700 Clincher hjulsett. Selges for 20 000,- kroner.
Ramme: Felt Tri Specific HM High Modulus Modular Carbon Fiber Frame. Full Aero Tubeset with front and rear wheel recesses, internal cable routing, forged horizontal dropouts
Gaffel: Felt Bayonet SL UHM Ultra-high Modulus Modular Carbon Fiber Carbon Monoquce Design with 3KP Finish, Carbon Blades, Dropouts, Crown & External Steerer with Felt 1 inch Bearing Compression Device
Front Derailleur: Shimano Dura-Ace 7900 braze-on, double
Rear Derailleur: Shimano Dura-Ace 7900 SS Short Cage
Shifters: Shimano Dura-Ace SL-BS79 bar end, 20 speed
Chainset: Shimano Dura-Ace (Helt nytt)
Chainrings: 53/39 Tooth chainrings
Bottom Bracket: Shimano Dura-Ace Hollowtech-II
Cassette: Shimano CS-6600 11-23t
Chain: Shimano Ultegra 10-Speed
Front Brake: Shimano Dura-Ace 7800 Super SLR Dual Pivot with Cartridge Brake Shoes
Rear Brake: Shimano Dura-Ace 7800 Super SLR Dual Pivot with Cartridge Brake Shoes
Brake Levers: TRP Aero Carbon
Handlebars: Felt Bayonet 6061 T6 Base Bar with Integrated Adjustable Length 7075 Aluminum Bend extensions and Alloy arm rests with High Density Foam Pads
Stem: Felt Bayonet SL Integrated 6061 3D forged Aluminum, Rise: -17 degree thru +43 degree range of adjustability, 95, 110, 125mm
Headset: Felt Bayonet 1 inch Integrated
Grips: Devox Tri-tip Ergonomic Base Bar grip with Felt Gel Ribbon Cork Tape Black with Felt 3D Logo wrapped extensions
Hjulsett: Shimano Ultegra 6700 Clincher
Dekk: Continental Grand Prix 4000 S
Sete: Felt 3.1 Tri/TT Saddle with Carbon Injected base, Gel Nose, Custom Waterproof Cover with Carbon Fiber Inserts and Extended Length CRN/TI rails
Seatpost: Felt 3.1 Carbon Fiber Bladed Monocoque Design x 310mm
Seat Binder: Integrated Two Bolt Replaceable Clamp
Vekt: ca 8 kg
Har dere noen spørsmål i forbindelse med annonsen så bare ta kontakt!
"Euro. It's not an origin or place of manufacturing. It's a style or an essence."
