Noen som har noen erfaring med dette kranklageret?
Adapter cups and bearings for pressfit bottom bracket shell.
Anodised 6061 alloy cups hold full stainless steel bearings and meet on the middle of the frame shell with o-rings to seal the crank axle and BB bearings.
Compatible with Shimano 24mm cranks and KCNC K-type cranks (without insert).
Designed for 89.5mm x 41mm and 92mm x 41mm frame shells
Compatible with KCNC K-Type and Shimano chainsets
