Mongoose Bootr TeamSykkelen er brukt en sesong og er uten feil. Liten bulk på rammen (kommet fra gaffel "bumper"). Helt ny bak demper (aldri brukt).
Color(s): Blue
Frame Material: New Mongoose FreeDrive DH 210mm travel and 150mm Maxle dropouts
Fork: Rock Shox Boxxer Team, 203 mm travel high/low speed compression, rebound and preload adjust, 20 mm thru axle
Rear Shock: Rock Shox Vivid beginning and ending stroke rebound and preload adjust, 241x76 mm w/ 19x8 mm hardware
Crankset: Truvativ Holzefeller OCT 1.1 hollow forged arms 36T ring
Bottom Bracket: Truvativ Howitzer TM (83 mm shell)
Pedals: Welgo MG-1 Magnesium sealed pedals
Rear Derailleur: SRAM X.O short cage
Shifters: SRAM X.9 trigger 9 speed
Freewheel: SRAM PG-950 Cassette 11-26
Chain: KMC Z9900
Rims: SUN A.D.D. Lite 32 hole (Malt Svart)
Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5
Front Hub: Ringle Jumping Flea 20 mm thru axle
Rear Hub: Ringle Jumping Flea 150x12 mm thru axle
Spokes: Wheelsmith stainless
Brake Levers: Elixir CR pad contact and reach adjust
Handlebar: Funn Full Bore triple butted AL7075 riser, 25.4x50x710 mm
Stem: FUNN RS 25.4x45 mm direct attach for Boxxer, CNC alloy
Grips: Mongoose Lock on
Saddle: Shimano PRO
Seat Post: BBB alloy, 31.6
Extras: E.13 LG1 ISCG05 chainguide w/ Taco bash guard (Taco Malt Svart)
14000 NOK. Bud mottas gjerne.
