Specialized Stumpjumper FSR Comp 2009 Medium
Specialized Stumpjumper FSR Comp 2009 Medium #1086498 19/12/2010 06:40
ØKD Offline OP
Selger min Stumpjumper FSR Comp. Størrelse medium. 2009 mod.
Ny veil. pris 25999. Selges for 12000. Sykkelen er brukt to sesonger, men ikke veldig mye..
Specs:
Frame:
Stumpjumper FSR M5 manipulated alloy frame with ORE Toptube/Downtube, Sealed cartridge bearing pivots, DMD Direct Mount Front Derailleur, Replaceable derailleur hanger (disc only) and 120mm travel
Rear Shock:
Fox Triad, Custom on-the-fly 3-position switch 1)Lock out 2)Open 3)ProPedal pedal assisting damping, Rebound adjust, 7.25x1.75 inch
Fork:
Fox Float 120 RL, 120mm travel, Compression and rebound adjust with LO, Alloy steerer
Front Derailleur:
Shimano M660 SLX, DMD, Top swing, Dual pull
Rear Derailleur:
SRAM X-9, 9-speed, Mid cage
Shifters:
SRAM X-7, Aluminium trigger, 9-speed
Chainset:
Custom Shimano FC-M542, 175mm
Bottom Bracket:
Cassette:
Shimano HG61, 9-speed, 11-34 Tooth Range
Chain:
SRAM PC-971, 9-speed with Power Link
Pedals:
Shimano M520, Clip less - OPPGRADERT til M540
Front Brake:
Custom Avid Elixir R SL, Alloy backed organic pads, 203mm rotor
Rear Brake:
Custom Avid Elixir R SL, Alloy backed organic pads, 185mm rotor
Brake Levers:
Custom Avid Elixir R SL Hydraulic, Tool-less adjustable reach
Handlebars:
Specialized XC low rise 31.8mm bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
Stem:
Specialized adjustable rise, 31.8mm clamp, 3D forged with CNC finish
Headset:
1-1/8 inch Threadless, 10mm insertion alloy cups, Sealed cartridge bearing
Grips:
Specialized Thick lock on grip
Rims:
Custom DT Swiss X420SL, 24mm with eyelets, 28/32 hole
Front Hub:
Specialized Hi Lo disc, CNC flange, Sealed cartridge bearing, 9mm DT RWS, alloy QR, 28 hole
Rear Hub:
Custom Shimano M525 SL, Alloy QR, 32 hole
Spokes:
DT Swiss 1.8mm stainless, Black, Alloy nipples
Front Tyre:
S-Works The Captain, 26x2.2 inch, 120 TPI, Kevlar bead, Dual compound, Tubeless ready
Rear Tyre:
S-Works The Captain, 26x2.0 inch, 120 TPI, Kevlar bead, Dual compound, Tubeless ready
Tubes:
Specialized Ultralight 26x2.0 inch, Presta
Saddle:
Specialized Format, Hollow Cr-Mo rails, SL foam, 143mm
Seatpost:
2014 butted alloy, Single-bolt setback, 30.9x350/400mm
Seat Binder:
Re: Specialized Stumpjumper FSR Comp 2009 Medium [Re: ØKD] #1086666 19/12/2010 19:48
Registrert: Dec 2010
atlesparby Offline
hvilken høyde passer denne medium modellen til.?
låses demperne forran og bak.!?
Noe slitt eller defekt på den.?
Re: Specialized Stumpjumper FSR Comp 2009 Medium [Re: atlesparby] #1087545 21/12/2010 19:20
ØKD Offline OP
Tipper den passer bra for de som er ca 172-182, pluss/minus. Jeg er 175 selv. Lock-out foran og bak. Ingen defekter. Et par små riper på ramma, men ellers veldig pen.
Re: Specialized Stumpjumper FSR Comp 2009 Medium [Re: ØKD] #1089414 28/12/2010 12:24
kwanon82 Offline
Hei
Er denne solgt enda?
